A few weeks ago I was on one of my Orcas trips and lo and behold there was the old Grumman sitting outside the hangar with a couple a folks doing what appeared to be an actual pre-flight inspection. I needed to do some more investigating. Yep, after 10 years, they were going to see if it would fly once again!
Both engines were started and I thought that this might really happen. However, after taxiing the plane over to the fuel pumps and putting a adequate amount of fuel in the tanks my hopes of seeing it fly sank. Avgas was literally pouring out of the wing exiting somewhere behind the port engine. The flight was called off for now. I gave up and walked into town for some grub disappointed that I would likely miss seeing the fist flight of the old bird.
About two hours later I returned to fly back to KBLI and there was the Grumman back out on the ramp. I was informed that the leak was fixed good enough to proceed with the flight. The owner and his mechanic taxied the old Grumman to the end of 34, did an extended run-up, lined her up and gave it the gas. It took off like it was waiting all the time for this day to be back doing what it does best.
They did a short flight around the patch and came back for an uneventful landing. The plan is for the new owner to take the Widgeon up to his cabin in Alaska to use for recreation. I can't think of a better place for it. It's really good to see a plane like this be brought back to flying condition by someone who plans on using it.
