Nosedragger wrote:Officials say that Hershey, 85, was attempting a landing at the airstrip. Prior to the crash, KREM 2 News is told the 85-year-old pilot was preparing for a touch and go. Experts say he pulled up instead, stalled, then crashed about 100 yards away from the air strip.
Witnesses indicated that the plane appeared to be experiencing trouble during its final approach. The plane veered off the runway where witnesses heard the plane crash.
Dr. Hershey is an ice skating buddy of ours in Spokane
...a kind and gentle and hardworking man who deserves everyone's good wishes..
One thing that stands out about the accident at Cavanaugh Bay is the whiteness that said that he seemed to be having a problem while on approach, then veered off the runway and into the trees, the flap on the left side are actuated by a cable as are mine on my 172 my repair manual also shows it that way on the 152 as well, then its possible that the cable broke on that flap causing the plane to veer off the runway, note the photo of the plane shows the left flap retracted, but then any thing can and does happen in an accident. There was a similar accident at my airport, the NTSB wrote it off to pilot error and wind conditions, the IA at my airport inspected the wreckage and found the flap cable broken. Imagine what would happen if suddenly with out warning one flap retracted and the other did not. I had an IA warn me about using a certain green cleaner on my aircraft;
it seems that it gets into control cables and between overlapping surfaces and promotes corrosion, there is also an aircraft friendly version of this product that I now use. Coincidentally the buried tie down cable where the cleaning product collected rusted through as if it were in salt water, the other two showed no sign of corrosion, coincidence I suppose.
Our hearts and prayers for the pilot.
