....14 CFR Part 39
[Docket No. FAA-2016-5579; Directorate Identifier 2016-CE-010-DA; Amendment 39-18586; AD 2016-14-05]
RIN 2120-AA64
Airworthiness Directives; Textron Aviation Inc. Airplanes AGENCY: Federal Aviation Administration (FAA), DOT. ACTION: Final rule. ––––––––––––––––––––––––––––––––––
SUMMARY: We are superseding Airworthiness Directive (AD) 2008-15-06 for certain Textron Aviation Inc. Models 175 and 175A airplanes (type certificate previously held by Cessna Aircraft Company). AD 2008-15-06 required checking the airplane logbook to determine if the original engine mounting brackets had been replaced. If the original engine mounting brackets were still installed, the AD required repetitively inspecting those brackets for cracks and replacing any cracked engine mounting bracket until all four original engine mounting brackets were replaced.....
