http://en.wikipedia.org/wiki/Aermacchi_AM.3
8GCBC wrote:O-540? O-720? Needs a PT6! Looks heavy.
Dot_AK wrote:The Lycoming engines were hard-run, and he never saw all 360 hp advertised.
150Mike wrote:Dot_AK wrote:The Lycoming engines were hard-run, and he never saw all 360 hp advertised.
FYI: AFAIK no Lycoming 480 CID engine was ever rated at 360 hp. The GO-480-B series was rate at only 270 hp and the -F series at only 275 hp. I believe the GO-480-C and G series engines were rated up to 295 hp. With the addition of an integral supercharger, GSO-480 series engines were rated up to a maximum of 340 hp limited to 5 minutes for take-off only. On the other hand, Lycoming's GSO-540 and IGSO-540 series engines produced up to 380 hp.
According to some of my reference books, the Aermacchi AM.3 Bosbok was equipped with a 340 hp Lycoming GSO-480-B1B6 (geared, supercharged, opposed 480 CID) engine.
Furthermore, all of those geared Lycomings could be temperamental and they were (still are for that matter) easy to damage the planetary gear reduction system if the throttle was "chopped" too quickly and the prop was allowed to "overrun" the engine. For that reason alone, I would think that it would not have been suitable for installation on a "combat" aircraft. They were much better and more common on the "cruisers" of the day such as Aero Commanders and Beech Queen Aires.
M6RV6 wrote:Lots of geared engines around that time in history were installed in a lot of combat airplanes. Was the only way to make that much power! Queen air started life as (U-8F combat) aircraft.
Lyc TIO-541 makes 380 hp with out gear
GT
I believe that it was used only on the Beech 60 Duke and the very limited production model 56TC Baron (a "short" 55 series/T-42 Baron fuselage with Duke wings or at least the 380 hp TIO-541 engines mounted on it.) The TIO-541 had about the biggest turbocharger I've ever seen on a "flat" (i.e. horizontally opposed) air-cooled aircraft engine and it (the whole engine not just the turbo) red-lined at 2,900 rpm! That's high for a direct-drive engine. At full power, the turbo whine drowns out the sound of the core piston engine and it sounds like you're running up a jet.
Sure was fun to get some altitude and find a big tailwind tho!! Helluva ground speed at times
