Headoutdaplane wrote:How much to ag pilots make? paid by the hour, day, or just salary?
Unfortunately in the first question, saying 'ag pilots' is almost as random as just saying 'pilots'… Between, varying application rates, varying season lengths, varying commodity values, and varying regions and all the ramifications that entails, what an
operator makes varies tremendously.
The financial relationship between aircraft reserves / operator / pilot pay , that Contact layed out is pretty accurate ( 50 / 25 /25 ) for the recip world. For the turbine world it usually leans more to something like ( 60 / 20 / 20), but that's not too hard to understand when you factor in the price of a PT-6 vs the price of an R1340. Which would suggest Dogone's research leans towards turbines. Fortunately for the pilot, the speed and payload of the turbines will generally more than make up for the difference
As a loose general rule, you can figure anywhere from 17%-25% of gross application rate for a hired pilot. And a very loose guesstimate of 100 acre/hr coverage. At this point many applicators are rolling their eyes and saying they do an easy 350 acres/hr, but they're also not telling you about the times they fire up, load, taxi out, ferry spray, and ferry back for a 20 acre load. The night before last I had
one job, and it
had to get done (in other words, no putting it off to tie together with something else). It was a seed crop, 1.6 acres of arugula. Factor
that in to your acre/hr average
Contact's pay rates per acre are also pretty much on target as well when you factor in a little for inflation. Off the top of my head I've done 2 gpa (gallons per acre) work anywhere from $7-$10, and as much as $30 on high volumes 20-30 gpa. Our rotor work is almost double the fixed wing, but the cost to run them is equally as high, and the speed to fly them is equally as slow, so the net result for the pilot is very comparable. Dry work just shifts the equation to wt. but works similar.
Some measure of work may be bid as a bulk contract or by hobbs time, but the vast majority, specially the daily bread and butter is all done per acre.
Dogone's hourly extrapolation is also pretty much on target per my personal experience, but I try never to get too wrapped up in the initial numbers. For me the end net is all I worry about. I have had some of the lowest per acre jobs turn into great paying affairs, and some of the highest turn into jobs I paid to do
. There are just too many other variables, and each job / position must be weighed on it's own merits / challenges.
The last fly in the ointment, is that flying ag for a living is essentially contracting. LIke all contracting, much of the
financial success is going to be determined by the individuals drive, background and networking abilities and there ability to use those attributes in concert.
Net, net… I personally know many hired pilots who are happy flying seasonally and do $30K - $35K per year, and also many who play harder and turn $300K - $350K / yr. Although as with most careers, the 'heavy hitters' generally pay a reasonably steep price somewhere else, after all, it's all about how much time you want to sit in an airplane / heli. The same is also true about the step between being a hired pilot vs. an owner / operator.
Long answer for such a short question again…
but hope it helps
Take care, Rob
