Pierre's post is a good one. I would point out (and correct me if I'm wrong, Pierre) that the turbo normalized Cirrus installations were originally done by Tornado Alley....the GAMI guys, and the "gurus" of LOP. I've heard the story that Pierre noted before, and it's interesting to note that most of the Cirrus owners operating those turbo normalized engines were in fact fairly closely following Tornado Alley's operating recommendations, I believe.
In other words, there's information out there that may or may not apply to every engine.
Another example: The four cylinder Lycoming engines, and what the hell, the six cylinder Lycs with carburetors.....For decades, we all operated those engines the way Lycoming said to operate them: Without "proper" engine instrumentation, you avoided leaning above 75 % power, and when you did lean the mixture, you leaned by ear...pull the mixture out till the engine stumbles, then push the mixture back in "a ways" to engine smoothness.
First time I ran one of these engines with an engine analyzer, I was curious to see where that procedure got me to regarding EGTs. The answer is, just slightly rich of peak EGT. Like, JUST slightly rich of peak.
So, what's my point? The point is, I've run several of these engines to TBO and beyond without ever having a cylinder off, using that procedure. Red fin???? Really?
Continental engines and Lycoming engines are VERY different beasts.
I have no fear of that "red fin" as far as leaning goes, but I will not lean an engine if its putting out more than 75% power.
