Nizina wrote:AKclimber wrote:For the flour bombings are you allowed to make a sighting tool?
It's a simple vector algebra problem - you have the horizontal (airspeed) and vertical (altitude) component of the triangle and then you just need to calculate the angle of the sight. Drop the flour bomb when the target is in sight.
What about air friction? Vertical air speed will increase until you hit terminal velocity due to air friction, while forward speed will continue to diminish to zero due to friction.
You are right, hence the altitude and area of target zone is important as to whether the triangle approximation is sufficient. If we want to make a 1 square meter target from 10,000 feet, then all kinds of new factors need to be accounted for...
