.shortfielder wrote:My 29's are Airhawks and came from AKBW. I think they also have the best prices on Cleveland brakes, and don't need to be rebuilt.
You can get airhawks with full tread, or shaved(saves 5lbs./tire). Shaved, they will still have some tread. I think you can also get them recapped??? If they are smooth, they are pretty much shot, far as I'm concerned.
If you go to wider tires(8.50's and larger) you will also have to off set your rotor, or get one with built in offset, and different torque bracket. Brake gets offset about 1/4".
Wup(AKBW) is the authority here, call him.
Actually, when those 29X10X11 tires are bald, they will STILL wear on a light plane for about a hundred years
shortfielder wrote:Actually, when those 29X10X11 tires are bald, they will STILL wear on a light plane for about a hundred years
Well,if they are bald, they do wear.
They may go for long time on grass or smooth dirt, don't know for asphalt. I understand that they are a very tough/long lasting tire. And am very happy with mine. I did have one flat on mine. And was surprised at how thin the casing seemed(4 ply).
I also feel for my application, dealing with cactus and sharp rocks, the more rubber the better.
Gary
