Ahh.. sorry I just saw that you have a 165 not a 220, sorry. Try Franklin Engine Co. (Formerly A-1 Service) - Source of Franklin parts, including pistons, rings, bearings and overhaul gasket sets. Founded by the late George Heinley, now operated by Susan Prall. P.O. Box 514, Jewett, Tx.75846, (903) 626-5115 . The website is receiving a "major overhaul" and is temporarily not fully operational. E-mail is
[email protected]
She has made a deal with and now has one of the better franklin mechanics at her site. She has and is expanding the number of parts for these motors that is now in production.
If your light cases have not cracked by now they most likely will not, however you can tell the case type, light or heavy by the casting numbers.
Here is the AD on the cases.
AD51-15-02 - Crankcase cracks
FRANKLIN:
Category - Engine Effective Date - Not Available Recurring - Yes
Supersedes - N/A Superseded by - N/A
FRANKLIN:
Applies to All Franklin 6A4-165-B3 Engines Serially Numbered 33046 and Below Incorporating Original Crankcase (Left Half No. 18305; Right Half No.18306). These Two Parts Form Crankcase Assembly, P/N 18553. The Number of Each Crankcase Half is Located on Each Casting Below the Number 1 and 6 Cylinder Location.
To be accomplished by July 15, 1951.
Effective on and after this date, all applicable crankcases with 500 hours of operation since new or 250 hours since last overhaul should be inspected as follows: Remove crankcase cover and visually inspect the webbing near the main journal area for cracks.
(1) Crankcases found to be free of cracks should be inspected at 250-hour intervals thereafter. In the event that the conditions described in (2) and (3) are detected, the provisions of (2) and (3) will apply.
(2) Crankcases found with (a) surface indications, hairline cracks, or small wall cracks and (b) cracks starting at main bearing stud hole on the opposite side from main bearing support, may be operated further at the option of the owner. Such crankcases should be inspected at 50-hour intervals thereafter to determine progress of cracks.
(3) Crankcases found fractured or with cracks that have progressed to the extent that they enter the main bearing supports (usually from back near (a) main bearing stud hole and (b) drilled oil hole) indicate that a complete break soon will occur. Such crankcases should be replaced with the reinforced crankcase assembly, P/N 18925, at which time no further inspection is required.
Crankcase assembly P/N 18925 may be identified by casting No. 18905 appearing below No. 1 cylinder location and casting No. 18906 appearing below No. 6 cylinder location.
(Franklin Service News No. 10 also covers this subject.)
I have some contacts that may have cases if you need them.
Dane
