Amphibious Ops on Ramps
Being new to the world of amphibious floats, before attempting to climb a ramp I’d like to get some of your sage advice on what to and not to do. I’ll be operating a MX7-235 on EDO 2500As.
tgrtom offline
4
Don't run a wing into a piling. Seen that done at our local marina by an ols duffer in a SeaBee. Doh!
Eric
10534
I've seen a number of ramps where the concrete pads have separations between them and have wide gaps between them that would swallow an 8" tire, OK for a 14 - 16" boat trailer, but not an amphib. tire......
mtnflyr offline
27
Well what the book says has always worked for me. Approach the ramp slowly and just before touching a burst of power with full aft elevator and then power as required to get on up. But like the previous posts mentioned, make sure the ramp is suitable.......Ron
Redbaron180 offline
147
Sat Jul 28, 2007 12:02 pm
And once you are on the ramp, DON'T hold full up elevator. Steep ramps and up elevator can put you on your tail.
Have your mechanic double check the downlocks on all four. I've seen downlocks that didn't quite hold right in water, and collapse a gear. A pain, but not a disaster.
Just take it easy coming into the ramp. People have done this millions of times and it's no big deal.
10515
