Here's an interesting article on general aviation aircraft type "angle of attack" instruments:
https://airfactsjournal.com/2025/04/vis ... yNnm-2-yVA
Belloypilot wrote:I have an inferred AoA on my Aspen system in the Bonanza and a vane-type CYA-100 unit in the Husky. I find both useful, but in different ways. Neither is some kind of be-all end-all life saving gadget, but when properly calibrated I think they serve as a useful learning aid when exploring how an aircraft behaves under different loading configurations at the ragged edge of the envelope, and knowing how far away you are from that ragged edge.
35 series Bonanzas are famous for having a CG envelope that can be significantly narrower than the physical limitations of how the aircraft can be loaded. That’s especially true with mine, as it has the Robertson RSTOL wing that further reduces the front of the envelope. The inferred AoA on final provides a good indication of the control authority I’ll have in the flare, which is nice when I’m dealing with a short field with a crosswind. It responds quickly enough, but the display location isn’t ideal once on short final. I don’t think I’ve ever looked at it past about 1/4 mile final.
The CYA in the Husky has been a great learning aid for me. It’s quite responsive, and provides a reliable indication of stall margin in slow, maneuvering flight. I have the stacked LED display as well as an inclinometer front and center on the glare shield so it’s visible without taking my eyes off where they should be right up to the point of touchdown. It’s been an excellent learning aid and helped me improve my landings on wheels, skis and floats.
The key to getting any utility at all from an AoA is getting it calibrated correctly. It’s not that difficult, and once initially calibrated it should be checked at different weights, CG, and gear/flap configurations. If that’s not done well the instrument is probably more of a hazard than a help.
All that said, in my experience the instrument doesn’t do anything that training and practice wouldn’t accomplish. As experience is gained, it becomes less useful. It served a purpose as a learning aid, and still helps as a rust remover from time to time. No way it ‘replaces’ airspeed.
My $0.02
Users browsing this forum: No registered users and 19 guests
