Hope this helps, this is one that we delveoped to "help" with 100 hrs and annuals.
ENGINE RUN-UP:
____ Engine temperatures and pressures
____ Static RPM
____ Magneto drop; note particularly any difference between the drop on the two magnetos Drop Left________ Right________ Difference ___________
____ Engine response to changes in power
____ Any unusual engine noises
____ Propeller response through pitch range
____ Fuel tank selector or shut-off valve; operate engine on each tank and off positions long enough to make sure the valve functions properly
____ Idling speed and mixture; proper idle cut-off
____ Generator warning light or ammeter
____ Suction gage
____ Fuel flow Indicator
____ Magneto switch shutoff at Idle – checking for grounding
ENGINE COMPARTMENT:
____ Oil cooler for security, leaks, and obstructed air passages
____ Induction air filter for servicing.
____ Entire engine assembly for cleanliness
____ Induction airbox for internal cleanliness, cracks, and security; doors for operation and sealing; controls for security and operation
____ Cold air and hot air flexible hoses for security, kinks, holes, chafing, and burnt spots
____ Engine baffles for security, sealing, cracks, metal deformation, and attachment of sealing strips
____ Cylinders for security, cracks, broken cooling fins; rocker box covers and push rod housings for security, oil leaks, cracks and dents
____ Crankcase, oil pan, and accessory section for security, oil leaks, safetying; front crankshaft seal for oil leakage
____ Check oil filter for contaminates and install new filter and safety
____ All lines and hoses for security, leaks, deteriorated hoses, and loose or corroded clamps; drain lines and hoses for security, leaks, and chafing
____ Intake system for security, leaks, deteriorated hoses, and loose or corroded clamps for security, leaks and chafing
____ Exhaust system for security, leaks, cracks, and burned-out spots, check for internal flame arrester cones
____ Ignition harness for security, chafing, burning, defective insulation, and loose or broken terminals
____ Spark plugs for proper gap, cleanliness, and evidence of reliable operation
____ Crankcase and vacuum system breather lines for security, obstructions, corrosion, cracks and chafing
____ All electrical wiring in the engine compartment for security, chafing, defective insulation, and loose or broken terminals
____ Vacuum pump for security, oil leaks, and safetying
____ Vacuum relief valve for security and the inlet filter for cleanliness, holes, corrosion, and safetying
____ Engine and propeller controls and linkage for security, proper rigging, binding, excessive wear, cracks, misalignment, corrosion, safetying and chafing
____ Engine shock mounts for security, safetying, deterioration; engine mount for cracks, corrosion, dents, bends, and evidence of overheating; ground straps for security, corrosion, fraying of braided straps, and cracking of metal straps
____ Cabin heater valve and door for proper operation, sealing, cracks, and deformation; controls for security, binding, proper rigging, and alignment
____ Starter for security, oil leaks, tight electrical connections; engagement lever for proper rigging and return spring tension
____ Alternator - check for security and oil leaks if generator is fastened to accessory case; drive belts for cuts, fraying, and excessive wear; electrical connections for security
____ Carburetor for security, cracks, corrosion, fuel leaks, cleanliness of inlet screen and proper safetying
____ Engine cowling for cleanliness, proper fit, security, cracks, dents, cuts, tears, loose or broken hinges, defective latches or fasteners, and deteriorated paint
____ Cowl flaps for cleanliness, proper fit, security, cracks, dents, cuts, tears, loose or broken hinges, and deteriorated paint; control for security, proper rigging and binding
____ Compressions: #1_____ #2_____ #3_____ #4_____ #5_____ #6_____
Magnetos:
____ Breaker points for security, pits, burns, and carbon deposits
____ Cam followers for correct lubrication
____ Ventilator screens for cleanliness and security
____ Magnetos for correct timing to engine, and security of attachment.
PROPELLER:
____ Constant-speed propellers for nicks, cracks, corrosion, bends, dents, loose nuts and bolts, oil leaks, freedom of blade movement, excessive looseness of blades, security, and proper safetying
____ Propeller governor for security, safetying, cracks, oil leaks; control for correct rigging, security, binding, and proper safetying
____ Spinner and spinner bulkhead for cracks, dents, alignment, security, and condition of paint
FUEL SYSTEM:
____ Fuel strainer for internal cleanliness, security, leaks, and safetying; drain valve and control for proper rigging, operation, leaks, and security.
____ Fuel tank sump drains for water and sediment, leaks, security, and safetying; quick-drain valves for proper operation
____ Underside of wings for evidence of fuel leaks; fuel tank filler cap placards for legibility; caps for leaks and security
____ Fuel vents for obstructions, operation of check valve, leaks, security, and proper position of vent behind wing strut
____ Fuel selector valve, or shut-off valve, for proper operation, security, leaks, positive detent positions, and legibility and correct indexing of placard
____ All fuel lines for security, chafing, leaks, cracks, dents, kinks and corrosion
____ Fuel line and selector valve drains for servicing, security, leaks, and safetying
____ Fuel quantity gages (direct-reading), electrical fuel quantity gages, and fuel quantity electrical transmitters for security, correct indication, defective wiring, cracked glass, legibility, and leaks ____ Engine primer for proper operation, leaks,
LANDING GEAR:
____ Brakes for proper operation, sponginess, failure to hold pressure, and fluid level
____ Master cylinders, brake lines, and hoses for security, leaks, cracks, dents, and chafing
____ Brake linings for wear, cleanliness, chips, cracks and security
____ Brake disks for scoring, warping, excessive wear, and loose or broken brake-clips
____ Wheel and brake assembly for cracks, dents, corrosion, leaks, loose bolts, defective paint, freedom of moving parts, and excessive wear
____ Axles for security, cleanliness, cracks, bends, defective threads; axle nuts for proper adjustment and safetying
____ At tire rotation or replacement remove the wheel bearings and inspect for cleanliness, rust, cracks, pits, scoring, brinelling, discoloration, excessive wear, and lubrication
____ Main landing gear spring for security, cracks, bends, deep scratches, dents, chipped or peeling paint, loose brake lines
____ Tires for proper inflation, sufficient tread, cleanliness, cuts, blisters, breaks, and uneven wear Check wheel alignment if tires show uneven wear
____ Tailwheel for lubrication, security, cracks; tire for proper inflation, cuts sufficient tread, breaks, and blisters; tailwheel spring, steering and anti-swivel mechanism for security, proper operation, cracks, frayed cables, and worn links
____ Parking brake for proper operation, correct adjustment, security, excessive wear, and full release
____ P Ponk attach bolts for security & integrity
AIRFRAME:
____ Pitot and static ports for obstructions; pitot and static lines for security, cracks, kinks, chafing, and moisture; pitot tube for alignment
____ Aircraft exterior for cracks, metal distortion, broken spot welds, loose or missing rivets, screws, and bolts, corrosion, condition of paint, and any other apparent damage or defects especially check wing and empennage tips for damage
____ Aircraft structure for corrosion, cracks, metal distortion, loose or missing rivets, screws, and bolts, and evidence of excessive loads
____ Windows and windshield for cleanliness, proper attachment, sealing, crazing, cracks, deep scratches, and discoloration
____ Door and window hinges and latches for lubrication, alignment, proper operation, cracks, distortion, binding, and security
____ Seats for ease of movement, positive locking, security, and seat stops; seat upholstery for rips, tears, holes and cleanliness; seat structure for cracks, bends, and corrosion; seat rails for security, cracks and damage
____ Safety belts for security, proper latching, cuts, tears, fraying, and broken stitching; attaching parts for cracks, deformed metal, and excessive wear
____ Control column for security, binding, cracks, looseness, and restricted travel; bearings, sprockets, and pulleys for cleanliness, lubrication, binding, security, and excessive wear; cables and chains for security, cleanliness, corrosion, fraying, binding, broken links, and misalignment; turnbuckles for safetying; bell-cranks for cracks, distortion, and binding
____ Control wheels for alignment, binding, security, bent tube, and excessive wear; control lock for proper operation and availability
____ Instruments for cracked glass, security, proper operation, cleanliness, and legibility of markings; gyro instrument air filters for replacement
____ Magnetic compass for security, fluid discoloration, leaks, lighting, and proper operation. Compass card for legibility
____ Instrument wiring and plumbing for security, chafing, leaks, cracks, kinks, defective insulation, loose terminals, and interference with control column travel
____ Instrument panel for security, deteriorated shock mounts, cracks, damaged decorative cover, and legibility of all decals and labeling
____ Defrosting, heating, and ventilating systems for proper operation, security, chaffing, and deterioration; controls for proper rigging, binding, and security; ram air inlets for obstructions
____ Cabin upholstery and trim for cleanliness, rips, tears, holes, and security; sun visors for security and proper operation
____ Area beneath floor for cleanliness, chafing and security of lines, hoses, and electrical wires; control cables for fouling
____ Stall warning horn for proper operation and security
____ Electrical switches, circuit breakers, and fuses for security, proper functioning, and legibility of placards; spare fuses for availability
____ Instrument and cabin lights for proper operation, security, and cleanliness; instrument light rheostat for proper functioning
____ Radios and radio controls for proper operation and security
____ Battery for servicing, security, and corroded terminals; battery cables for condition of terminals, security, and defective insulation; battery box for cracks, corrosion, damaged mounting brackets, and security; vent line for corrosion, security, and obstructions
____ Firewall for proper sealing, security of grommets and shields, cracks, dents, wrinkles, loose or missing rivets, screws, or bolts, and evidence of excessive loads
____ Radio antennas for cleanliness, security, proper connections, corrosion, and cracked housings
____ Navigation lights, landing lights, flash beacon and strobes for proper operation, security, cleanliness, and cracked glass
____ Pitot heaters for proper operation
____ Door Stewards for attachment and security
AILERON CONTROL SYSTEM:
____ Ailerons for correct direction of movement when operated from the cabin
____ Pulleys for security, cleanliness, binding, misalignment, cracks, cracked or deformed pulley brackets, and chipped or broken flanges
____ Cables for cleanliness, security of terminals, corrosion, fraying, correct tension, and safetying of turnbuckles
____ Bell cranks and push-pull rods for cleanliness, lubrication, security, binding, cracks, and distortion
____ Fairleads and cable guards for security and excessive wear
____ Aileron system for correct rigging and proper travel
____ Ailerons for security of attachment, smooth operation, security of balance weights, cracks, corrosion, and skin or structural damage
FLAP CONTROL SYSTEM:
____ Bellcranks and push-pull rods for cleanliness, lubrication, security, binding, cracks, and distortion
____ Flap system for correct rigging and proper travel
____ Flap control lever for security, proper operation of latch, lubrication, and binding; flap decal for legibility
____ Flaps for security of attachment, smooth operation, binding rollers, cracked, bent, or loose tracks, corrosion, and skin or structural damage
ELEVATOR CONTROL SYSTEM:
____ Elevators for correct direction of movement when operated from the cabin Pulleys for security, cleanliness, binding, misalignment, cracks, cracked or deformed pulley brackets, and chipped or broken flanges
____ Elevator system for correct rigging and proper travel
____ Elevators for security of attachment, smooth operation, security of balance weights, cracks, corrosion, and skin of structural damage
STABILIZER TRIM CONTROL SYSTEM:
____ Pulleys and sprockets for security, cleanliness, binding, misalignment, cracks, cracked or deformed brackets and chipped or broken flanges or teeth
____ Cables and chains for cleanliness, security of terminals, corrosion, fraying, correct tension, broken or damaged links, and safetying of turnbuckle
____ Fairleads, cable guards, and chain guards for security and excessive wear
____ Trim control wheel for lubrication, cleanliness, security, binding, and operation of friction stop and position indicator; indicator for correct indexing and legible markings
____ Stabilizer actuators for security, cleanliness, lubrication, proper operation, corrosion, cracks, and excessive wear
____ Trim control system for correct rigging and proper travel
____ Movable stabilizer for security of attachment, smooth operation, cracks, corrosion, and skin or structural damage
RUDDER CONTROL SYSTEM:
____ Rudder for correct direction of movement when operated from the cabin
____ Rudder pedal assembly for binding, cleanliness, lubrication, security, cracks, bent linkage, and excessive wear
____ Cables for cleanliness, security of terminals, corrosion, fraying, correct tension on “closed” systems, and safetying of turnbuckles
____ Rudder system for correct rigging and proper travel
____ Rudder for security of attachment, smooth operation, security of balance weight, cracks, corrosion, and skin or structural damage
EMERGENCY LOCATOR TRANSMITTER:
____ ELT for proper function, check remote “on” and “reset” buttons work correctly, check battery replacement dates of ELT and in remote switch. Complete FAR 91.207 (d)
Notes:
...Guywagon
GuyWagon... Member #77
