For those thinking about buying one of these as discussed in Barnstormer's 185 mod thread, they're on sale for $85 here: http://jbtoolsales.com/antigravity-batt ... fgod3EwASg
Durango Skywagon wrote:Hey MTV-
I'm no electrician, but any one see a problem with getting 2 of these and hooking 'em up in series for 24 volts?
Brad
bigrenna wrote:Certainly there are those that don't care at all, but Im a bit confused as this battery is not certified for aircraft use. The Odyssey J-16 is, which was the basis for its use in the various firewall STCs.
Barnstormer spoke of a "recommended" battery with his bat box. STC's usually don't recommend but explicitly list P/Ns to use. The FA Dodge STC SA02333AK-D Dc. NO II-I005 calls for ONLY the SBS-J-16. Other than internet conjecture and grey area interpretations of AC 43.13, what is the actual basis for this install? From where I sit, w/out the PMA or explicit documentation, it cant be installed (legally that is.)
The FAA has been easing on some issues like the use of 8.5x6's on 170-185s etc, non-certified angle of attacks, and non-certified portable electronics in the panel, but these were all done with official documentation.
I would love to loose some more weight with a battery like this... What am I missing?
Terry wrote:bigrenna wrote:Certainly there are those that don't care at all, but Im a bit confused as this battery is not certified for aircraft use. The Odyssey J-16 is, which was the basis for its use in the various firewall STCs.
It just goes with your tool kit.
I have one, that I have used a couple of time to jump 4 wheelers.
flylow wrote:I bought the anti gravity battery back in October to throw in the tool bag / survival kit. I've jumped my truck and a couple 4 stroke snowmachines. I haven't jumped the airplane battery but I don't think it would have a problem doing so. After jumping a snowmachine battery, the anti gravity battery charged my iPhone for four days. I don't think I could get more than a jump or two out of it. Only time will tell if the battery is worth it or not. It's been handy so far.
172heavy wrote:In the Boeing 787 Dreamliner's first year of service, at least four aircraft suffered from electrical system problems stemming from its lithium-ion batteries. Although teething problems are common within the first year of a new aircraft design's life, after a number of incidents including an electrical fire aboard an All Nippon Airways 787, and a similar fire found by maintenance workers on a landed Japan Airlines 787.
I know this must be all just rumor and old technology, Yea right!
And Yes lead acid batteries do explode, a loud pop and acid dripping every where, been there done that, but I have never heard or read of one failing in thermal runway, like I have seen on a LI battery, I'm not saying that LI technology is not the up coming thing, but ignoring the possibility of a potentially hazardous condition in the cockpit can and has killed people, throwing one of these baby's in your tool box and have it short out or get damaged can or will start a fire. The most likely cause of the disappearance of MA 370 was the LI battery cargo that it was on board.. Do an internet search on LI fire hazards, You may also take the time to educate your self on charging and discharging LI batteries, people that use them in RC have a much better understanding of these than some one using them in a power tool or motorcycle, How do you know if your getting your full capacity out of your batteries? Do you load test them and check balance on your cells like we do that fly them in RC aircraft?Or do you just put them on a charger and call it good, That's what I thought.
