Mr. Ed wrote:
Since the brake peddles need to be depressed when the cable is tensioned for the parking brake clips to click into the detent and it takes two feet to do that, how exactly does this occur?
I would suggest, strictly from a human factors engineering standpoint, that Maule consider relocating the left cabin vent knob to a position in close proximity to the right cabin vent knob. Food for thought.
Agreed 100% on this one...on our model the P-brake knob is located right next to the carb heat knob. They are the same color and everything so it is easy to see how a pilot could inadvertently pull the wrong one.
I have wondered myself how the brake could be set with inadvertent foot action, but I can tell you that there is significant wear on the air duct located on the firewall directly behind the P-brake cable. The cable does not touch this duct during normal operation, so it has been speculated that it is caused by hitting it with the feet. It is all Monday morning quarterbacking, and the only thing we know for sure is that the brakes were not activated by pulling the lever, the pilot confirms that he pumped the brakes prior to landing, the brakes were locked on landing, and there is significant wear on the duct behind the cable, . We are just going to disable the P-brake while it is down and do away with the problem entirely. We have never (intentionally) set the parking brake since we have owned it anyway.
Jeremy-
No disagreements with you on adding the brakes to the GUMP list. I do it myself and have not ever had a problem with the brakes. I also learned tailwheel flying in a Supercub so I fly with my toes on the bottom of the pedals (heel brakes in the SC) until I need to slide them up for brakes. This is different from my partners foot placement as he uses the entire pedal all the time. Not that my way is better, just different.
As I stated earlier I was not in the aircraft when this event happened, just passing on information from the pilot concerning the chain of events that seem to have contributed to the problem. As with most problems, if we remove any one item in the chain of events, the problem could have been avoided. In our case, a firmer push during the pre landing brake check
may have disengaged the P-brake, ensuring foot placement on the pedals
may have prevented inadvertent P-brake engagement, landing on grass
may have prevented nose over, etc. etc. The easiest fix in our case is to just disable the P-brake since we have never had a reason to use it and it will eliminate the problem entirely.
