Mike,
From 500 feet or higher, we appear or seem to be moving toward a distant target slowly. If we look down at our left main tire and count telephone poles, we appear to be moving much faster. While our speed is the same, we appear to be going faster when our field of view is limited. This same phenomenon occurs as we approach closer to and lower to the numbers. If we are on a stabilized approach at a constant airspeed, the speed at which we appear to approach seems to speed up the closer we get. This is if we are looking outside at objects and the numbers and not looking at the airspeed indicator, as during an instrument approach. By the time the numbers go under the cowl, we appear to be closing with the numbers very fast. If we round out and look on down the runway, the speed appears to slow back down to the original rate we were going before.
The trick is to use this incorrect rate, this apparent rate, to alert us to the fact we are going really too fast for a really short field or too fast for a fairly short field. By maintaining or stabilizing this incorrect rate, this apparent rate, we actually slow down over the last quarter mile and last 500 feet altitude of an approach so as to arrive at the fence with no need to round out. There is no need to round out because we don't need to slow vertical speed and forward speed. We have already done that by the gradual speed reduction caused by maintaining a constant apparent closure rate. Our airspeed will be slowing during this process. Our rate of descent will increase requiring more power. More power will force more air over the wing. Our pitch attitude will gradually increase from 500 feet and a quarter mile, and then increase a little more rapidly from short final on in. Our power will gradually increase to maintain the stable descent rate and then increase more rapidly as we get really close.
This is not to say we don't still control descent with power as needed and apparent forward speed (apparent rate of closure) with elevator as needed. It is just a normal power/pitch approach. The only difference is that pitch controls apparent speed, not a stabilized 1.3 Vso.) Wait! There is an important safety difference: we don't get really slow, and with a tailwind probably go behind the power curve, until really close and entering ground effect. Yes! In a tailwind this approach can safely be made to less than Vso on touchdown with a lot of pitch, a lot of power, and no bounce.
Thanks for the questions Mike, I think this visual phenomenon is or could be useful for the kind of flying a lot of these guys do. I want to do anything I can possibly do to explain it. That includes flying with you, Cary, and other instructors and pilots if possible.
Jim
