JP256 wrote:Got mine done by an avionics shop / official dealer. All up cost was just over $5K. They did a great job, and I like the unit a lot so far. Very easy to use. While they were in the panel, they fixed my aux power port so I can recharge my iPad Mini 4 (ForeFlight) in flight. I also had them attach the mounting bracket for the Stratus 2 to the glare shield, and run the ESG's pass-through antenna/power cables through a grommet in the glare shield so they come out right behind / beside the Stratus. The grommet is tight enough that the wires don't move much, and it will prevent the connectors from falling through the glare shield. This setup means my Stratus gets power, ADS-B antenna, and GPS signals all from the ESG, and I can set it to power ON when I turn on the avionics switch. That set of cables was well under $200, and is a really slick solution. (And with different cables, you can use it with other Aviation GPS/ADS-B IN units, not just the Stratus.)
Funny story on the AUX port... There was a 20A inline fuse (yes, you read that right - 20 amps), and it was piggy-backed off the Turn & Bank circuit. Turns out the T&B fuse (10A) was bad. Funny how I noticed the AUX port not working, but never seemed to notice the T&B was not working. I guess the only time I looked at the T&B was to check the "ball"...
Anyway, it's all ready to go. Now if the weather would just cooperate a bit, I'll go fly my ADS-B Validation flight, and file for my rebate... We've been having 20G30 knot winds and 45+ knot winds at 3000 feet for the last few days. As a new tailwheel pilot (35 hours TW time), that wind is beyond my personal limits, even if it is almost aligned with the runway. (Not to mention that the bouncy ride would not be a whole lot of fun...)
theamherst wrote:Question for you guys with the appereo adsb out; is there a way to turn off the adsb function when not required? I would prefer not to broadcast all of my vitals to the world in the event that I might inadvertently make a low pass somewhere or some other indiscretion. I suppose you could just turn the whole thing off but it would be nice to only disable the adsb function.
Thanks.
aftCG wrote:Sorry for the thread diversion but I have a specific question about your aux power in your 7ECA. Namely, how do I legally add an aux power outlet to my plane?
flyingzebra wrote:FWIW, we mounted the Stratus module vertically in the glovebox. It works great that way and is nice and clean. As I understand it, the only requirement by Appereo is that the long axis of the module be aligned with the axis of the aircraft. My install does work great in that configuration and is nicely out of the way. The one caveat is that, unless you have a really good memory, you should set the Stratus to automatically turn on when powered up and turn off with the power off. Otherwise it's out of site and out of mind and it takes a long time to recharge from zero after being left on. This, I also know from my install.
