robw56 wrote:They are also compatible with shoulder harnesses which is what I will add once my kid outgrows the car seat.
denalipilot wrote:robw56 wrote:They are also compatible with shoulder harnesses which is what I will add once my kid outgrows the car seat.
Hey Rob, do you already have the Cessna part for the rear shoulder belts in a 170/2? I can send you an example if you like. I have them installed. You're right that the buckle in the system I posted doesn't accept the BAS-style utility buckle ends, but it's fine for the open-loop style of shoulder harnesses, a la Hooker, etc.
-DP
swixtt wrote:Thanks for the feedback... DP i'd like to see what you've got there? can you send or post it up?
i think i'm due for replacement webbing sometime soon ... i'm guessing mid-70's era
i'm the same as you Rob. kids use and then changing when they get bigger. yes.... they.
robw56 wrote:DP, those are cool. I've never seen those before. I like how they are quicky removable.
A1Skinner wrote:Those are awesome DP. Wonder if a guy could put a set in a 180?
swixtt wrote:hotrod, see these...
http://blog.aopa.org/vfr/wp-content/upl ... heet-C.pdf
http://blog.aopa.org/vfr/?p=1217
thanks for posting those pics DP!
denalipilot wrote:swixtt wrote:Thanks for the feedback... DP i'd like to see what you've got there? can you send or post it up?
swixtt and Rob:
Here's the setup I was talking about. Rob- it goes into the same strap-reinforced nut plate/ bulkhead that you described. I know the hook is OEM Cessna, and I believe the harness hardware is too. I understand they're not too common. It is quite secure in a downward/ forward pull direction, but you can install and remove the rear shoulder harnesses in seconds. It's kind of tight for adults, great for kids- nothing you didn't already know about a 170.![]()
-DP
hotrod180 wrote:I've seen those quick-attach shoulder harnesses, but was just now unable to find a source for them.
FWIW I had a set of Aircraft Spruce "style 3A" should harnesses in my last airplane.
They have an attach fitting at the upper end with a single bolt hole,
you can just bolt it to the nutplate in the spar carrythrough.
The lower end is a pair of loops sewn into the webbing, they just slide onto the lap belts.
Sounds cheesy but they worked very well. I liked them.
Cheap too, at less than $75 each. Here's a link.
http://www.aircraftspruce.com/catalog/a ... ness3a.php
Grassstrippilot wrote:Does anyone know if you go with the 3B version of those belts, will the ends work with any normal lap belt buckle? Or do you have to replace them as well? Those two flat pieces that the male end of the seatbelt buckle goes thrift takes up some space. Just not sure if a standard buckle has the space needed to accommodate them.
