Mon Apr 06, 2009 11:37 am
Y4,
The 18 gallon aux tank is widest at the top since the bottom curves to match the Cessna belly. Top measurements are 31.25 inches wide, 24.25 inches long (front to rear), and 7.5 inches high, not counting the fill neck.
I had one in a 1974 Cessna 172 that worked well. They pump up to the right side wing tank. You were not supposed to fly on the pump flow only, although, I know I could in that plane, at least once.
I do not have the fill cap that goes in the airplane side (it was flush mount like some motor cycles etc have, and connects to the tank filler tube. Nor, do I have the electric fuel pump or fuel gauge, or any paper work.
I paid $600 for this tank, plus S&H. I’d like to get that $600 back, but I’ll spring for the shipping for the US. Before I bought this, if I remember right, a guy in PA had the kit with STC for around $2750.
