obxbushpilot wrote:I know this won't work out in the field (unless you have electricity), but is anyone using 1200 watt hairdryer? One of my friends in Ak uses these exclusively to preheat. They don't last forever, but he buys them at yard sales and close-outs and has a box of them on hand. They work well too. I haven't used one yet as my plane has a Tannis system installed, but he preheated a plane last October in Talkeetna in a pretty short time. Fitrst time I had seen it done. He swears by it.
rjb wrote:Since heated air can hold more moisture, there is an argument that leaving a preheater on can expose your engine to moisture
http://www.reiffpreheat.com/FAQ.htm#QA3
The above article mentions a March 2007 Aviation consumer article that has an excerpt that their experiment shows leaving a preheater on dries the engine out.
My experience is that a rodent thought the air intake became a snug winter home.
-Dick
bumper wrote:Mongo,
Good find!
Not to take away from McMaster-Carr, I source from them all the time. The heat pads you reference are suggested to be installed with a heat control device (i.e. thermostat). MC's, at least the ones I found, are pricey. When added to the cost of the heat pad, might as well buy a ready made one. If using these heat pads without a thermostat, read the specs on max heat output and consider that most petroleum based oils start to break down around >240 F. So you'll probably want a thermostat to cycle off at <160 F or so. Also, if using one of these pads without a thermostat, it may be prudent to select a size 150 watts or less so as to minimize the risk of overheating in moderate temperatures. With thermostat, something on the order of 300 watts will provide more rapid preheating and will provide more adequate heating at lower OATs.
For an inexpensive thermostat switch, this one at Amazon is $10. Opens at 140 F and closes at 125 F that should do fine.
http://www.amazon.com/Senasys-Limit-Sty ... 43&sr=1-84
For those disinclined to break out the soldering iron and put their own sump heater together, this one is a reasonable option and works well on a couple of planes I have:
The E-Z Heat (Aircraft Spruce $150) comes with a thermostat, power cord with plug - - and is at least twice the price of the "build your own" from MC + Amazon option.
bumper
EZFlap wrote:Sterno canned heat fuel can, inside a safety shroud, attached to a duct?
