I might as well throw in a little for you. When buying my plane I looked at a Stinson 108-3 with a 150 hp Franklin. I never flew in it and as it turned out the motor was bad. The Stinson was pretty comfortable to sit in. But after talking to the owner about getting parts for the franklin and the fuel consumption, I decided against it. I bought a '57 PA22/20-160 for $23,000 with a high time motor. I knew in advance that I would be overhauling the engine in about 100 hrs (turned out to be less than 50). While the engine was being overhauled I put VGs on and can tell you that they are the single best investment you can make for a pacer. The pacers don't have very good aeliron response at slow speed and the VGs pretty much take care of that. They lower the stall speed some as well. The only other mod I've done is get the STC for 8.50s from Svenn's Aviation. This STC is also good for 26in tires too. I've had 26in Goodyears on now for about 20 hrs and am very happy with the way they handle on the ground. They also make it easier to push the plane in and out of the hanger, not to mention easier for the plane to accelerate, and with the increased angle of incidence, take off shorter. Like someone mentioned earlier, I took the rear seat out and now I can put a pair of bicycles (tires and handlebars off) and all the camping gear my wife and I ever need. At gross weight @ sea level with a temp around 70 deg F, I use about 800' to get in the air and around 1500 to clear 50' obst. When I'm by myself, I can get in the air in about 400' on pavement and clear 50ft in about 1000'. Last week I landed with 12kts straight down the runway and stopped it before I passed the numbers. Be careful, they will absolutely land shorter than they can take off!! She will cruise at 118mph indicated while turning 2450rpms (yes that's with the 26's) burning just over 8gph. I like to fly along at around 1900-2000rpms at 95mph and burn around 6-7gph. Again, as mentioned before, bring someone with you that knows tube and fabric planes. Have them look at the frame behind the baggage area and under the seat and battery spaces . If it has an older O-320 motor with the smaller valves, make sure that the valve ad has been done. Oh, and last of all, no matter what you buy, have fun flying!!!
