EZFlap wrote: Believe it nor not, it might be worthwhile to develop fairings for bush tires.....
Skalywag wrote:When the panties are that big, u don't wanna take em off [emoji28]
hotrod180 wrote:EZFlap wrote: Believe it nor not, it might be worthwhile to develop fairings for bush tires.....
How about a set of spats like Maule used to out on their airplanes, suitably sized and mounted for fat tires?
Give the wheel assembly that aerodynamic teardrop / raindrop shape.
EZFlap wrote:hotrod180 wrote:EZFlap wrote: Believe it nor not, it might be worthwhile to develop fairings for bush tires.....
Yeah, that's what I was thinking. Use the front of the tire as the forward fairing, and fair in the rear with a cone shape like some of the antique airplanes did. If the whole assembly can rotate upward (axle CL as the pivot axis), you could get the fairing out of the way for takeoff and landing.
contactflying wrote:He said they helped a little but he just liked the look.
hotrod180 wrote:
How about a set of spats like Maule used to out on their airplanes, suitably sized and mounted for fat tires? Give the wheel assembly that aerodynamic teardrop / raindrop shape.
I have a theory, totally unproven, but imagined based on my limited experience with aerodynamics, a far simpler flat bit of material sticking out the back of a wheel, just like the "spats" will give nearly the same benefit the complex spat would give. I am imagining a flat bit of thin, semi-flexible plastic, perhaps 12 to 20 inches square (leading edge curved to follow the tire), oriented perpendicular to the ground, directly behind the wheel. The intent being creating a fence that prevents the two turbulent air streams from mixing, thereby redirecting the air back, around the low pressure area directly behind the tire and into some semblance of symmetry by the time they mix off the back end of the "fence".
Once my plane build is done that is on my list of experiments. Unfortunately the issue of Spats-up and Spats-down must still be dealt with, so not sure if it will be practical, even if it does work.
That's all that's really needed. The vortex street is super draggy. Cutting down on that increases aero efficiency quite a bit.
The best visual I've ever seen is on wikipedia. Watch the two videos this link hits:
https://en.wikipedia.org/wiki/K%C3%A1rm ... g_problems
