Backcountry Pilot • Backup AI Recommendation
49 postsPage 2 of 31, 2, 3
Re: Backup AI Recommendation
Cool beans. I just checked it out.
Thanks!
I have my D1 mounted in the instrument hold using the adapter that comes with the unit. Then I connected it to ships power. It has a battery backup. You can see how it looks in this photo.
Squash offline
Prosaria wrote:....The D2 only gives you GPS ground track. The GRT unit I talked about above will act as a DG independent of the GPS with a remote magnetometer.
To me, the beauty of the D2 is that it is a stand-alone device-- no remote magnawhatchamacallit, pitot / static connections, etc. Clip it in, turn it on, and go. The D2 has speed, rate of turn, slip/skid ball, vert speed, altimeter, horizon, and ground track-- a whole 6-pack in one 3-1/8" hole. I don't much care about it not being a true DG when ground track is what I'm after. The "airspeed" on the D2 is GPS-derived so is actually groundspeed, but that's OK since I already have a pitot/static-driven airspeed indicator. The main things I want is the horizon, all the other stuff is just a bonus. May be too much stuff going on in one 3" gauge, but I believe that it has the ability to deselect some of the displays.
The GRT Min-GA has that same ability. It just clips in like the D2 and you up and running. The mini is a little more money but it has some extra features that are kinda cool. Nice to have a couple different options for very similar devices.
Yep the GRT does exactly what the D2 will do like you describe but has the option to do more. It really is a nice unit, at least it looks that way. You can add the pitot static module and it will do AOA, airspeed and ROC as well (using a separate system so as to not run afoul of the FAA). I also like that it will calculate the crosswind for you using ground track and magnetic heading.
Prosaria offline
Squash wrote:I have my D1 mounted in the instrument hold using the adapter that comes with the unit. Then I connected it to ships power. It has a battery backup. You can see how it looks in this photo.
Perfect, it looks like it will work fine for me.
Nice glamour shot, by the way!
Prosaria offline
I have a good publicity agent.
Squash offline
hotrod180 wrote:
hpux735 wrote:....Personally, I'm only interested in devices certified for primary instrumentation, because that's the only way to get rid of the vacuum system on a certified plane........
I assume that you're talking about for IFR use. The vacuum horizon & DG on both my old C170 & my old C150/150TD were optional per the factory equipment list, and I removed all that junk on both of them. They're also optional on my 1953 C180, and I've thought of pulling them out of this one also, but since it's more of a traveling machine I would like to have something "just in case". A Dynon D2 fits the bill for being light, simple, long-lifed, and also for having a bunch more tricks up it's sleeve than just attitude. It is also Wi-Fi capable so that the D2's GPS can feed a sectional-based moving map display on an ipad or similar. I don't have one now, but I might get one in the future to replace / supplement my G196.
Yep, exactly. I'm not ifr yet, but once I get a plane (in the next 3-6 mo), it'll be the first thing I'll do.
hpux735 offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... ViDjGmD0RW
Squash wrote:I have my D1 mounted in the instrument hold using the adapter that comes with the unit. Then I connected it to ships power. It has a battery backup. .......
How much does it stick out from the panel?
Dynon says 3.63" x 3.26" (face) x 1.16", but I don't know if that 1.16" is the thickness of the face or if maybe part of that 1.16 sticks through the 3-1/8" instrument hole.
Prosaria wrote:Yep the GRT does exactly what the D2 will do like you describe but....
Maybe not. I googled up the dimensions of the GRT Mini-- it will not fit into a standard 3-1/8" hole, and with a 4.35" x 3.94" face it's too big to fit in the middle positions of a standard 6-pack flight instrument lay-out-- at least the one in my airplane. For me, the Dynon D2 looks like a better fit, both physically & capability wise. I don't know that I'd want synthetic vision on top of (or more accurately, underneath) the normal display-- the screen's already pretty busy with attitude/directional/airspeed/altimeter info.
glacier offline
Maybe not. I googled up the dimensions of the GRT Mini-- it will not fit into a standard 3-1/8" hole, and with a 4.35" x 3.94" face it's too big to fit in the middle positions of a standard 6-pack flight instrument lay-out-- at least on my airplane. For me, the Dynon D2 looks like a better fit, more physically & capability wise. I don't know that I'd want synthetic vision on top of (or more accurately, underneath) the normal display-- the screen's already pretty busy with attitude/directional/airspeed/altimeter info.
You need the mini-ga not the regular mini which needs a square hole.
Prosaria offline
glacier wrote:Take a look at Trutrak ADI too. They have pitot static connections but work fine without them; the pitot is for a low airspeed warning (nice, but not needed if you scan your airspeed instrument) and the static can just use cabin pressure.
They will fit in normal 3 1/8 or 2 1/4 holes, but probably do not follow along 100% spirt of this letter that GRT references, because there is no "mounting device" other than putting it in your panel:
http://www.grtavionics.com/PS%20ACE-23-01-R1.pdf
Is the Trutrak a solid state unit? Not much info about it on the website. But I like that it has vsi and DG built in.
glacier offline
The entire unit is external to the instrument panel attached to the clamp that sits in the 3-1/8" hole. If the specs say that the unit is 1.16" thick, then plan for that much plus a little extra for the thickness of the mounting clamp.
Squash offline
hpux735 wrote:.... I recently read that there was a rule change that lets you (potentially) remove all the vacuum parts from your plane and go all-electric. This is cool to me because the vacuum pump MTBF is something like 500 hours, a vacuum-driven AI is around 1000 hours, and an electric gyro AI is a few 1000 hours. A solid-state gyro is more likely to be in the neighborhood of 10,000-100,000 hours. In addition, it'll weigh less, and won't have the parasitic load on the engine. Personally, I'm only interested in devices certified for primary instrumentation, because that's the only way to get rid of the vacuum system on a certified plane.....
I think the FAA policy statement allows for the replacement of a vacuum horizon with a solid-state one, but it like the vacuum unit it replaces it must be certified for IFR use. Probably something like this RC Allen 2600 series digital horizon.
http://www.aircraftspruce.com/catalog/i ... ca2600.php
But hang onto your hat- they list at $2600!
L3 Avionics makes a nice backup unit but it is not cheap. It's the trilogy.
Bdiazair offline
keep them flying!
Squash offline
Thread hijack alert: Nice helmet man! I have been looking closely at the Evo helmets and would appreciate any feedback from someone actually using them who is not selling them. If this question gets enough answers maybe we could move this to a new thread.
-M3X
M3X offline
-M3X
https://www.backcountrypilot.org/forum/gallet-helmet-with-bose-a20-17072?p=241831#p241831
Go here and we can pick up the conversation about the helmet. I actually used this photo in that thread because it showed it in action. See you over there.
Squash offline
