Battery 185C
Need a new battery for 185 Cessna. Anybody have make type for cold weather starts?
Dirt offline
2
- Aircraft: Cessna 185
http://www.concordebattery.com/flyer.php?id=38This is the one I have. By a completely qualitative measure..."how fast it spins"...it works well. Only "cold weather" it's seen is the 30's in Idaho but from the research I did it has the highest cranking amps.
Also, I had an 180 with the firewall battery before. That plane lived it's life North of the border. Ton of guys run those batteries with absolutely no issue.
Bill
fiftynineSC offline
390
- Aircraft: Cessna 185F
Thanks will check out web
Dirt offline
2
I have an odyssey on my 180 and it's been working fine here in northern Canada. But maybe you live in a colder place?
David
5186
