Zzz wrote:I mean: What is the finest degree to which you can adjust EGT temps with a carburetor? Does the mixture control on a MS design carb allow for as fine an adjustment as that in an injected system? How sensitive do your fingertips have to be to twist the knob to such a fine degree?
It's pretty touchy.
Once level with the prop pulled back, I pull the mixture fairly quickly until I feel the power fall off, then forward just a tad (maybe a half turn back towards rich). This puts it in the ballpark of peak EGT. I let it sit for a minute or two until the EGT stabilizes, then go further rich very slightly (1/4 turn max) to which way the EGT moves. If it falls, I know I'm ROP. If it rises I know I'm LOP.
Either way, I lean or enrich *very* slowly to find peak EGT. This can take several minutes as the probe is slow to respond. By slowly, I mean I turn the mixture knob enough to take up the slack in the vernier, then just a few degrees more and wait. Repeat until I get peak EGT.
From there I do the same thing to go LOP. From peak EGT, it requires very small adjustments and a lot of patience. If I'm down to 15 LOP, sometimes I'll overshoot to 25-30 LOP even with the smallest movement of the vernier. I can't imagine it's even possible without a vernier mixture knob.
I can usually move the EGT a couple of degrees either way, but it literally feels like I'll take up the slack in the vernier, put a touch of pressure on it, and even that slight pressure is enough to move the EGT. So it's touchy, but very doable. Definitely more sensitive than the IO-550 was.
