Backcountry Pilot • Best to start "Annual" during Spring/Summer (completed)
25 postsPage 2 of 21, 2
Re: Best to start "Annual" during Spring/Summer (opinion)
Railchummer wrote:After the 6 months of rain we just endured in the PNW having my plane down now is driving me nuts. This past winter I think you could count the nice VFR days in western Washington on your fingers. After I get the thing back together I intend to religiously annual it in December/January so as to not squander a single available VFR day starting in the spring. Thermal underwear is now as thin and light as a T-shirt and will fit nicely under a pair of coveralls if required, and a couple LED floodlights take care of the darkness issue. I'd rather dress warm in winter than lose a flying day in the spring. If you have to inspect your aircraft outside I guess you're stuck, but at this point I'd drag my aircraft under a portable awning and inspect it in full rain gear rather than lose a spring/summer flying day. And it's not just flying that's lost during a spring/summer annual; it's the fishing, hiking, camping, etc. that goes along with it. Smallmouth are spawning in the Yakima, walleye are biting in the Columbia, there's opening day cutthroat at Henry's Lake, etc., etc..
That scheduling works for you and that's great. My opinion respectfully...I would not enjoy being locked up in a hangar with artificial light and heating for a week or two servicing an aircraft in the dead of winter. Been there.
Wip's customer service department sent me some cool stuff with my order! Kind of like AKBW used to send Bar-B-Q sauce as a gift with their orders.
Note: no stinking button on top!
Amazingly the bottom and tail cone of the fuselage (the corrosion danger zone on a seaplane) is in great shape!
A few screws needed the threads cleaned:
Nut clip (was the only one) needed to be replaced. Worked like an anode?
Pre-Solve (LPS) is wonderful (environmentally friendly) use it everywhere these days:
Cable tensions good to go:
Cleaning and lubricanting cabin this morning....
Annual Inspection complete! Signed with (1) discrepancy: Compass requires calibration and deviation card.
Time: (6) days, which included general maintenance.
Next project: Fly to Alaska on June 21 on amphibs...
Re: Best to start "Annual" during Spring/Summer (completed)
Probably the best maintained 8GCBC I've heard of!
If you don't have a brass screwdriver, I've found that biting one end of a skinny coffee-stirring straw flat does the trick in a pinch. Or taking apart a cheap pen and doing the same to the plastic ink tube. The old shiny Skilcraft clicky pens had brass ink tubes that worked real good :D
CamTom12 wrote:Probably the best maintained 8GCBC I've heard of!
Well, thank you for your compliment! Also, I like your ideas for a screwdriver.
I normally use a bronze welding rod (or SS, AL) with the end filed straight off. Must of left it in Honolulu somewhere.
Fly safe!
