Bonanza Man wrote:a64pilot wrote:A Mooney slips well with flaps as far as I remember. The speed brakes are way cool, instant 500 FPM descent and no trim change. Mooney flaps are not nearly as effective as say the Fowlers on a Cessna and VFE if I remember right is 112 kts and VLE 132, so you get gear first which is backwards so to speak.
Do you mean that most high performance retracts are able to put out flaps above their gear speed? In my Bo max flap speed is 130 MPH and all the gear speeds are 162 MPH. Also does that imply you use flaps before you put the gear down? In a Bo there's never a reason to use flaps before gear and in fact Bo instructors teach it that way, helps to avoid gear up landings.
BM, Most of my Mooney time was in a 121 school.(Central Texas College) They were training pilots for the airlines primarily, I was a little unusual as I was getting my college degree so I could stay in the Army.
Anyway they wouldn't let you use the speed brakes or let you drop gear before the flaps. I assume that most bigger aircraft get approach flaps first then gear. Because of their training methodology you had to get the little Mooney slowed to below 112 kts outside of the outer marker or you weren't going to land. Seemed stupid at the time, but it did teach you to think well ahead of the airplane. Their reasoning was that they weren't training Mooney pilots, they were training Commercial pilots. Some of the other things they taught that did make sense was if you were holding, then you were doing it at max endurance airspeed. I took my Commercial ride before the Instrument ride and took the instrument ride in a complex airplane, both stupid things to do, I found out the hard way. My first license was the Commercial, I never had my private, so my training was a little unusual.
