Big Tailwheel
Wed Aug 20, 2014 12:58 pm
You probably already know this, but you can run a regular tire (need to look up the specs) with the ABW wide fork. That seems like a pretty sweet setup.
1259
- Aircraft: C180B
Oregon180 wrote:You probably already know this, but you can run a regular tire (need to look up the specs) with the ABW wide fork. That seems like a pretty sweet setup.
This is true, when my baby bushwheel wears out I plan on putting one of the ribbed tires and tubes on it. Much cheaper and should offer just as much flotation.
3263
- Aircraft: 1957 C-180A
robw56 wrote:Oregon180 wrote:You probably already know this, but you can run a regular tire (need to look up the specs) with the ABW wide fork. That seems like a pretty sweet setup.
I think like the bushwheels on the mains, the tubeless construction of the baby bushwheel tire lets you run much lower pressures for some added suspension. That's what that $440 tire gets you beyond the flotation. A normal tubed setup and you risk it coming off the bead.
2855
Scolopax -
The 3400 tailwheel fork kit from Alaska Airframes (Alaska Bushwheels) costs $607.00 without a tire.
Alaska Airframes sells the 4.00x4" "Ribbed Glider Tire" for $66.67 and a 4" tube for $22.17.
No flying report....yet.
MCH offline
64
