macktruckfarm wrote:Don't forget, octane requirement decreases w/ altitude, so if one always flys high, perhaps one could take off and climb on 100LL, then switch to Mo gas for cruise, don't know exact numbers for octane requirements vs. altitude, though. I don't know if the TCP research guys would know, if they are still around.
I am wishing that if Swift Fuel becomes approved, perhaps all the alcohol producers could be switched to Swift Fuel, thus no more alcohol problems?
I had this discussion about altitude and auto fuel with Ly-Con Visalia when reworking my 180 (HP) to 10:1 pistons. I got the go ahead with the following advice. The manifold pressure is the gauge to watch and is the early warning system on detonation, which is what we are trying to avoid. Low density altitude ops, cold temps and WOT with low octane would give the worst combination. They suggested limiting 26 or below manifold pressure to provide the saftey net.
Concerning Swift fuel, franchise costs for duplicating their formula and the comparative profit levels to ethanol and the RFS rules will determine how much we see.
