Yep, unless your local airport can be persuaded to leave some suitable snow on the grass alongside their runway, it's time to get creative. This is where highways adjacent to lakes and fields have been known to enter into the equation.
It can help if you have big enough tires to land on snow, where you can then install skis. That kind of operation is usually all about timing- be ready to do it on the day when all the conditions are favorable, or you can be waiting weeks for the next good combination of weather, snow cover, temps, and an airframe that isn't encased in ice.
Or stick the skis on, and be ready to relocate the plane the first time it snows, before the runway is plowed. You can even shovel a little snow into a hangar to provide a surface to slide the plane plane out on, if you need to.
A congested airport, among lots of other people's planes, is a very poor place to attempt ski-taxiing for the first time. Whatever you do, allow yourself a lot of room to practice the ground handling, or get someone with experience to move it away from confined quarters. This is especially true if conditions are windy and/or icy.
Fueling is a trick, like Bob says, but I assume your burn rate in a Luscombe isn't too bad, so if you have to transfer fuel in jerry cans, or tow a drum out onto a lake with a snowmachine, it's not as bad as fueling something in the high performance category. Just study and heed all the fuel-transfer posts on this site and others.
Another consideration is preheat, if you have no electricity where you tie down. I can run a propane forced-air heater off of a 1KW Honda generator, or if I'm traveling, I keep a Northern Companion preheater in the plane. You'll also want a good insulated cowl blanket. Wing and canopy covers come in very handy as well.
Then be prepared to figure out the whole deal in reverse come spring time.
If this all sounds like a lot of work, it's because it can be. But stick with it, it's worth it.
-DP
denalipilot on Tue Oct 21, 2008 6:32 pm, edited 3 times in total.
