Bose A20 ear pad alternatives?
Tue Sep 24, 2024 11:37 pm
My headset is getting a bit worn and I need to replace therarpads. Over here in Norway, original Bose ear pads are getting difficult to find. But there is a lot of third party alternatives out there. From Oregon Aero to super cheaå chinese ones. Has anyone tried any of these and could make a recommendation?
Varanger offline
137
With ANR stuff I like OEM, I also replace them (pad, ears and muff) yearly
It’s not like passive DCs, when the seals get bad the ANR attributes really start of fall off
- Retired
1678
I also assume that OEM`s are have better all round «tuning». That’s why I am wondering if anyone has positive experiences with third party stuff.
I can get Bose originals, but I have to pay quite a bit more for international shipping. Some of the others are avaliable through Amazon and will total a lot less.
Thinking big picture, maybe some tens USD extra is worth the security of knowing they work. They are quite essential after all :/
Varanger offline
137
I replaced mine with Oregon Aero this summer. Hard to install but once I got them on they worked well. They're a bit larger than OEM so my entire ear fits inside the cup better. The foam is a little stiffer so they didn't seal as well over the hat band from the ball cap I was wearing. However, once I pulled the edges of the hat up, out from under the ear pad, the seal was great and it worked even against an R-985 at takeoff power.
dabridgham offline
23
Wed Sep 25, 2024 10:53 am
My understanding is the theory with ANR is you need a good seal around the ear for the ANR to do its thing
- Retired
1678
I highly recommend the Oregon Aero ear pads and the headset cushion. I have always found the OEM ear pads and headset cushion to be quite uncomfortable, particularly the headset cushion, and the Oregon Aero products are a huge improvement in comfort.
pipeliner offline
158
- Aircraft: '57 C-182A floats/wheels
Doing some research on the OAs I found someone saying the ANR didn’t work quite as well as with the OEMs. You haven’t noticed anything like that?
Varanger offline
137
