Backcountry Pilot • Brakes
Brakes
8 postsPage 1 of 1
Brakes
I don't like the braking on my 172 with the 8.50x6 tires on it so I ordered the Cleveland Double Puck brakes (with STC) from Alaska Bushwheels today. After we get those brakes on 614, I'm going to go for a field approval for the Goodyear TSO'd 26x10.5x6 tires for the mains.
Anyone else put those tires on a 172?
Don
Okie Bush Man offline
you can get, or make spacers between the brake disc and wheel to give that clearance, jg
Cleveland or somebody (ABW?) makes those ring spacers. Probably a bd idea to just use washers, as having the whole flat surface of the disc bearing on the wheel (instead of just bearing on the surfaces of 3 washers) is probably a good thing.
Eric
Brakes
Alaskan Bushwheels makes and sells 1/8" spacers and longer bolts for just this application. I just upgraded from 6.00 x 6 mains to 8.00 x 6 mains and had a similar problem with caliper clearance. I'm installing the spacer/bolt kit today. Good luck.
48RagwingPilot offline
I too needed spacers when I went to 800's and got them from Wup. He sent them out immediately and I had them on a couple of days. Put 2 1/8th spacers on for a quarter inch clearance. I Found that when I rotated my calipers to the front and went to 800's from 700's that the calipers rubbed slightly. I followed Jeremy's advice and put the calipers in front as opposed to behind the gear. I guess that doesn't apply to Cessnas but it is a good idea for Maules.
iceman offline
I just updated my order with Wup to include the spacers and longer bolts for my 172. It sure don't look like any other lower 48 172.
Brakes
I just installed the spacer kit that I got from Wup at Alaskan Bushwheels. I now have about 3/8" clearance between the tire and caliper and hope that's enough. I probably should have used both spacers, but we'll see what happens. Anyone have any thoughts about the 3/8th?
More than enough space.. You only need about a quarter inch even less from what I was told....Are your calipers in the front?
iceman offline
8 postsPage 1 of 1
