Utah, the lower the pressure (on pavement) the quicker they'll wear out...it's because as the tire rotates it flexes as it contacts the ground, and that flexing moment is a scrubbing moment. It's that scrubbing action that wears them, the same thing as the scrubbing action from the gear moving through it's travel... on cubs they wear on the outside edge and so they need to be rotated often. Not the whole assy, but actually the tire flipped on the wheel.
I run mine hard on pavement, and 8-10 otherwise, I like to see a lot of "belly" in the tire and a wide footprint. If I'm going to one of the fishing holes that's really rocky I might be as low as 5, but I'm probably a bunch lighter than you guys...
This is my second set of radials, and I had a set of bias plys before that. I like the radials a lot more.
a64, if I was an outfitter with a couple working cubs on b-wheels I would be all over patrol guys wheels. having a spare set will save the day the first time you have a flat and need to keep the cub going. I was happy I had a spare when I ended up with a flat way out in the sticks...
FWIW this has been my limited experience with b-wheels...
Take care, Rob
