hotrod180 wrote:Assuming the prices are comparable, I'd be inclined to choose the Cessna.
Beside's Rob's dad's experience... there was a pretty favorable article in the 120/140 Club newsletter some years ago entitled "A Mountain 140" about a similar airplane. Keep it light & keep the prop pitched pretty flat & it'll kick ass. You might be bumping up against gross at times with camping gear but keep it in CG and it'll be OK.
hotrod180 wrote:If it's the one in Bend it sounds like a pretty decent airplane & a pretty reasonable price.
wannabe wrote:G-Knight
"Two rows staggered" Care to elaborate and educate an elder?![]()
Might save me some research.![]()
W
SamIntel wrote:.... It is a bit nose heavy which makes landing slow a little tricky as it runs out of elevator early in the flare when slow. It would definitely benefit from a higher angle of attack on the ground. Tail hits first with a slow landing, and it won't pop off the ground until well above stall speed because the angle just isn't there. But I think larger tires and practice will fix this. Upgrades in the future will be Desser 8.50s, VGs, and a flatter prop.....
