C-180 O-470 R Cyl Head Temps.
My Cyl. No.6 runs about 270 deg during cruise. Can go down almost to 250 at certain phases of flight. Others are Aprox 65 deg. warmer except No. 1 which I would like to have cooler.
Cyl.6 is the one up front on the left side, has anyone put an aluminum plate up to say half the cyl. head height to increse its Temp. and how did it affect temps to No.4 and 2?
[email protected] offline
151
- Aircraft: Cessna 180 Skywagon
Just did a 185 520 with same problem worked on both side. Did them like my 180k with 520 that has airforms pressure baffles . Cylinders are with 30 degrees. Look on there web site as to what u need to do
Cub180 offline
92
- Aircraft: Cessna 180 skywagon, Supercub pa18
Yes putting an aluminium plate part way up works good. Use some qluminium tape and work it up a bit by bit until you are happy with the temps, then fabricate out of aluminium. Easy way to get it right without having to mess around with your fabbed plate.
5186
Another factor is that the balance tube between cylinder banks on the front of the engine can cause the EGTs to fall very low on the forward two cylinders in colder weather. It is a common modification to insulate that tube. Here are two different scenarios that I have observed:
There is still a pretty good delta, but at least they are all above 300F in warmer conditions.
Scolopax on Sat May 08, 2021 9:21 pm, edited 1 time in total.
Scolopax offline
1696
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 4aYqSexnZC
Aryana on Sat May 08, 2021 8:42 pm, edited 1 time in total.
Aryana offline
936
- Aircraft: 1955 Cessna 170
Sun May 09, 2021 12:32 pm
Thx for the good Info. and ideas.
A-1
Very seldom do I fly 520 and 550 Skywagons but on the C-206 what I get to see is No.1 and 2 Cyl´s. to have the highest CHT´s.
Just like my 180 with O-470.
151
[email protected] wrote:Thx for the good Info. and ideas.
A-1
Ok, mine is a 206. I'll start my own thread so I don't derail yours.
Thanks v
5186
151
Case solved.
Cyl 2-4-6 now sometimes even just 10 Deg. Diff.
Oil cooler plate also raised temps to get 180 at cruise.
151
A1Skinner wrote:Yes putting an aluminium plate part way up works good. Use some qluminium tape and work it up a bit by bit until you are happy with the temps, then fabricate out of aluminium. Easy way to get it right without having to mess around with your fabbed plate.
That's a great idea. I had my right front (O-360) running cold, it has no vertical part, while the left front has a 1" vertical across both the head and barrel. I fabricated an aluminium part for the head only and that has helped, (270 up to 300 - the other three are 330/340s), but Im going to try the barrel as well now. Wish I had thought of the tape.
1269
[email protected] wrote:Case solved.
Great job. Looks good, works good. Success.
Aryana offline
936
