Mon May 04, 2015 10:57 am
Forget the paperwork for a moment, the legality is obvious and is not quite as relevant as other issues. Putting race engine modifications into a passenger / back country airplane.... without addressing the limitations and extra precautions that were acceptable and necessary in racing.... may not be the smartest thing.
Putting hi-comp pistons in makes more power. No question about that. It also puts more stresses on several internal parts of the engine. It makes a lot more heat.
A mechanical issue with an engine in a back country airplane may have more serious consequences than your average bug smasher flying around over farm fields. There was a reason the race airplanes went to Reno in a trailer.
I'm NOT saying that higher compression will or will not cause a problem in the O-300. The engine will take mild power modifications without too much complaining. We did horrible things to the O-200 in F-1 and never threw a jug. I melted one once but that was not because of compression. The big point is that the power gain needs to be balanced against any reliability loss, the use of automotive fuel, the cooling capacity of the baffling... and whether or not you are flying a single seat airplane in a Nomex tuxedo with medevac rotors turning nearby.
One guy that needs to be involved in this discussion is Harry Fenton, formerly of Slick/Unison, and a well-known expert on the "small Continental" engines.
When you look at Klaus' webspage that Hotrod linked to, you will notice that he mentions several things of interest. First, he calls out 100 octane fuel, which not all back country airplanes run on all the time. Then he says that near-perfect cylinder bores are expected. If you know Klaus as well as I do, and he uses the word "perfect".... you're talking about engine building and constant maintenance at a far higher level than most workhorse airplanes get. That is exactly how Klaus achieves most of the miracles he is known for.
Another item of interest is that his hi-comp pistons are paired with his ignition system. The ignition advances and retards the timing in a way that prevents detonation and high compression problems in conditions where there would otherwise be a risk of engine damage.
Again this is not intended as "the sky is falling!" if you boost the compression on your O-300. Just don't throw the pistons in without carrying out a proper analysis and test, and assessing the risk/reward.
If you want a bolt-on power increase without that much time/risk/effort/testing, then put one of Klaus' ignition systems on the engine. Same paperwork issue, but better power, better fuel burn, etc.
