After thinking about it for over a year, I finally plunked down the dough for a Micro VG kit for my C150/150TD. Although I've heard nothing but glowing reports about installations on Pacers, I have heard mixed reports about the results with Cessna's.
The kit was very complete, with excellent directions for laying out the installation templates. The gluing was messy but I managed to accomplish it without gluing my finger to my nose (or anything else). Now for the moment of truth....
The results were somewhat underwhelming. The sales brochure sez they reduce the stall speed 8-10%. I saw maybe a 2 mph reduction from the old stall speed of about 40 indicated, which is a full 5% -- not bad, but still only 2 mph. I did see some improvement in low-speed aileron response. but probably the biggest improvement was increased rudder effectiveness. So I did get some improvement, but given the chance I don't think I'd go for it again- at least not on a Cessna.
As part of the same program, I also pulled off the prop & had it repitched from the weak side of 57 to the strong side of 54. This gave me about a 100 rpm increase & helped shorten the takeoff roll. BTW this prop was bought new 3 years ago, ordered as (& stamped as) a 56-- I guess they don't worry too much about accuracy when pitching it at the factory.
Doing the math ( rpm X pitch / 1056), this should have given me about 6 mph less cruise speed at 2500 rpm, but I only saw a loss of maybe 2 mph.
Also speed-wise, when I installed 850's instead of 800's, several people told me I'd see a lot less cruise. Not so, I cruised at about the same speed at the same rpm-- but I'm pretty sure that I was pulling more manifold pressure. More drag is more drag, after all, and there's no free lunch.
I've also found that the heavier you are, the better they do their job. Yes there are some "STOL" benefits, but they're not a STOL kit...
