Backcountry Pilot • C170 Fuel Flow
C170 Fuel Flow
8 postsPage 1 of 1
C170 Fuel Flow
I was looking into a C170 with a continental, and the owner said they get around 110mph at 8-9gph.
If I weren't headed anywhere fast, is there anything wrong with prolonged flight at lower RPMs to decrease fuel flow?
I was looking at a Citabria, and it seems that according to the POH you can run it around 2000rpm to keep at at about 100mph and 5gph if you're not in a rush. What about the same thing with a Lycoming?
Thanks,
Jesse
PilotRPI offline
Re: C170 Fuel Flow
I've got a stock 170A. I'll run the C-145 at 2250, at 3500-4500 msl and burn ~6gph. She'll give me 90-95 knots, but carb ice is even more of an issue than normal operating like that.
YMMV. (literally)
TonyG offline
Besides, always know which way your aeroplane is pointed.
Re: C170 Fuel Flow
in my experience continentals run at low power settings start burning oil.
River rat offline
Re: C170 Fuel Flow
You can plan on 7.5GPH for 90% of your flying at approx 100KTS turning 2450RPM. Obviously you can pull it back and save more.
jugheadF15 offline
Contributing author
Re: C170 Fuel Flow
Ya I saw consistently 7.5 gph and 110 mph TAS with a climb/cruse prop. #2 cylinder likes to fail Went thru 2 of them in 550 hours.
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Re: C170 Fuel Flow
Any issues with running a lycoming O-320 at low power settings for long periods?
PilotRPI offline
Re: C170 Fuel Flow
jugheadF15 wrote:You can plan on 7.5GPH for 90% of your flying at approx 100KTS turning 2450RPM. Obviously you can pull it back and save more.
That was my experience with my C170 also.
Re: C170 Fuel Flow
We have C170B with 145hp O-300 and seaplane propeller. In normal cruise its fuel flow is a bit over 6gph, 2450rpm and 92KTS. It is possible to fly even slower, but it is quite slow then. :D
wingman offline
8 postsPage 1 of 1
