OK bright and experienced minds. I'm stumped. My skywagon has a single channel EGT and no CHT. During cold weather the other day, on take off at full power, the EGT was about normal. At 500', when I pulled the power back to 24.5" the EGT went UP significantly. I played with the aircraft on the ground and again in the air and this is a constant and repeatable response to pulling the power back. I have to pull the power to about 20" to get the EGT to come back down to a normal high power indication.
At my A&P's suggestion I did check for intake leaks and found one loose clamp but tightening it produced no change whatsoever. Also idle RPM is normal. I am running 92 octane MoGas and have been for the last year.
Any ideas would be appreciated.
FZ
