Backcountry Pilot • C66 Propeller, O 470L & PPonk Super Eagle
4 postsPage 1 of 1
Does anyone know if the C66 propeller is compatible with the 230 hp O 470L and the PPonk conversion O 470-50?
Help please!!!!
Mrchipz offline
Re: C66 Propeller, O 470L & PPonk Super Eagle
Yes, many have field approvals for a C66 on the Pponk engine. I ran that way for about five years, worked great.
The 86" 401 that replaced it pulls noticeably harder; but is heavier, more expensive, and slower by a few knots.
aqua offline
Mrchipz wrote:Does anyone know if the C66 propeller is compatible with the 230 hp O 470L and the PPonk conversion O 470-50?
Help please!!!!
Although currently running an MT, my O-470-50 is made from an 'L' core, and I did have a C66 field approved to it. Shortfielders O-470-50 also had a C-66.
On a nose heavy airplane, this actually may be a better choice than some of the heavy 3 blade props more often used...
all depends on the mission...
Rob offline
Ours is a L core also. With the PPonk I really don't think I will need the 3 blade take off performance as I climb out very well now witht he 230 hp, even at max gross. Appreciate the advice guys; the C66 seems like it will fit our needs. Lots of cross country and lots of local flights around the Puget Sound with not much off airport stuff.
Thanks.................TOM
Mrchipz offline
4 postsPage 1 of 1
