emflys wrote: It's small enough that you might just be able to use crack dealer
Zzz wrote:emflys wrote: It's small enough that you might just be able to use crack dealer
Yes.
EZFlap wrote:Fairly simple, you're looking at about an afternoon worth of effort not counting paint.
Put two or three coats of automotive wax on the cowling, and rub it off like you are waxing the car. Take clear packing tape or shelf paper and lay it down on your blue jeans, then peel it off the fabric. This kills about half or 2/3 of the adhesive. Then re-apply the tape or shelf paper onto the waxed cowling at least 6 inches all around the hole.
Cover the exposed engine parts with a few rags into the hole. Then cover the rags with thin packing tape or shelf paper. Get some OIL-based clay... not water base. Push the clay into the hole around the rags and onto the taped cowling. Shape the clay using small plastic paint scrapers, popsicle sticks, fingers, playing cards, spoons, etc.
Apply two or three layers of medium fiberglass cloth, somewhere between 4 layers of 4 ounce, or 3 layers of 9 ounce woven cloth. Forget about which direction the fibers are running... unimportant. Stick the first layer to the clay by hand, then carefully "wet out" the cltoth using a disposable brush. Apply each layer and wet it with laminating epoxy until there are no white (dry) spots.
If you don't know someone who can give you a cup of epoxy, and you have to go buy it, the easiest stuff is West Systems 105/205 with the little pump dispensers. But any good THIN laminating epoxy will work. The glass cloth should cover the clay and extend two or three inches onto the (taped) cowling.
Wipe away any epoxy that has run or dripped but try to not disturb the glass cloth. Let it cure completely, probably 4-6 hours. You can help it along by warming it SLIGHTLY with a hair dryer, or settingup a little space heater pointing at it.
When it's completely dry, mark a Sharpie line around where you want the perimeter of the bubble. Then drill four or six fastener holes through the fiberglass and through the cowling (before you remove the bubble). This will allow you to Cleco the bubble back into position and use screws to hold it on.
Peel off the bubble carefully and remove all the tape, rags, etc. Trim the perimeter of the mounting flange using tin snips. This is dishonorable cheating for professional level composites people, but it works fine and is a lot less tricky than the gurus using "knife-trim" or "green-trim" halfway through the cure cycle. Sand the cut edge smooth using 220 grit paper.
IF you are willing to remove the bubble each time you remove the cowl, then you can install Rivnuts or Tinnerman clip nuts to hold the bubble,a nd proceed to Bondo and paint. If you want to permanently mount left and right halves of the bubble to the cowl halves, there is a whole other process for that. If anyone is interested I'll describe thet otherwise you can just remove the bubble before splitting the cowl.
