WWhunter wrote:The same addative that is in Cam Gaurd is also in several of the aviation oils now on the market. It just has to be called by its chemical name due to trademark crap. This was told to me by the Shell distributor wt Oshkosh. He told me which oils have it in them but I don't remember which ones it was. You could pose the question to them and see what they say.
Keith
NOT true. In fact, the fellow who created CamGuard worked for Exxon, as I recall. My understanding was that he tried to get them to add this additive to their oil, and they wouldn't since it would have increased the cost of their oil, and therefore competition would be tough. So, he went out on his own.
To the best of my knowledge, the chemicals in CamGuard are NOT incorporated in ANY standard aviation oils.
Give Cam Guard a call and chat with them. They're good folks to talk to, and very knowledgeable.
In response to the initial question, CamGuard CAN also be used as a preservative oil, at a higher concentration than would normally be used. I've used the stuff since it first came out, and I firmly believe it's helped, since my airplane sits idle for weeks at times.
I highly recommend using Cam Guard regularly, and as I noted, in your case if you wanted to use it as a preservative oil while you're deployed, that works as well. Read the instructions. Here's their web site:
http://www.aslcamguard.com/aircraft/Note that Camguard is virtually the only oil additive that is approved by both the manufacturers and the FAA.
