dirtstrip wrote:I have no experience with the O 300 but isn't it about the same engine as a O 200 with two more cylinders? I think then it should be like the O-200 arrangement. The oil pan does not surround and heat the intake air like the Lycoming and is more susceptible to carb ice. ...
Glidergeek wrote:I've got about 600 hrs in a C170 with an O-300A and can only remember 1 maybe 2 instances of carb ice enough to make the engine choke and cough with the application of carb heat. Put a carb temp gauge in it and keep it in the green.
