This past week I got a new STC'd oil cooler installed. It's a pretty cool
A long, long time ago someone made an oil cooler that mounted to the side case of C85's, C90's, O-200's and OE-300's. I've looked , but have never found one let alone seen one. Besides you can't use a spin-on filter with that model and I like the simplicity of a spin-on.
Three days ago while it was still about 99 deg. I did a flat out VX climb for over twenty minutes. I went from 1400 MSL up to 8500 MSL with an IAS of around 60 MPH. My oil temp was somewhere around 205 to 210 but then never went any higher. As soon as I leveled out it dropped to 190 in about one to two minutes. I also tested it last Saturday afternoon, but it wasn't as hot as last Monday. Saturday's temp was around 85 deg. and I pushed it up to 10,100 MSL in about 25 minutes. My oil temperature that day never exceeded 195.
I'm really happy with the outcome, but would like to installed a damper that is cabin/cable operated. With the damper I could close off the air when getting too much cooling. In the winter time I'll just tape/block the air inlet, but in the "changing of the season's" temperatures it would be nice to regulate the effectiveness.
I believe the STC is or is going to be available for Cessna 150's, 170's and 172's.
Roger
