Backcountry Pilot • Cessna 180/185 Tie Down usage for Hammocks
While not directly aviation-related, survival and basic wilderness skills, sometimes called "bush craft" are an important part of flying the remote backcountry.
5 postsPage 1 of 1
All,
I regularly use hammocks for back country hiking, fly fishing and hunting trips...but literally just got a 185 (used to have a super cub)...curious to the owners of Cessna's what your take would be about hanging the hammock from the tie down and the other to a tree? Doable or not advised? Thinking it would be a great way to stay covered on calm evenings without having to put up the tarp.
- Jake
Steelefx4 offline
Aircraft: Cessna 185
Re: Cessna 180/185 Tie Down usage for Hammocks
I wouldn’t.
I'm also an avid hammock sleeper, and I've given it considerable thought. My conclusion is that it's a real bad idea.
First off, it puts a side load on the tie down ring which wasn't engineered for that.
Second, the vector force of a load suspended between two distant points is considerably higher than the load itself. Every time you jostle and bounce while getting arranged in the hammock you significantly increase that vector force. Your 200lb body could easily exert 600lbs of force on your tie-down ring, in a direction it was never meant to be stressed.
Third...you're going to have to be tucked up real close to a tree, or string out a lot of line and then pull it all taut enough that your but doesn't hit the ground. Being able to park that close to trees isn't real common, especially for a airplane that's too heavy to really push around by hand. And the more distance between anchors and the tauter you pull the line, the higher the vector force being applied to your...er...vintage airframe. You could top a thousand pounds of load on your tie down ring real easy.
All that said, it might be fine. I just don't see any real upside to finding out, and a lot of potential downsides. My hammock has an attached rainfly, so I don't see any advantage to being under the wing, and honestly, condensation or rain running off the wing often makes it a worse shelter than just being out between a couple trees.
Just my take...14 years of hammock camping out of an airplane.
Hammer offline
Thanks for the replies! Sounds like I will not be attempting!.
Steelefx4 offline
I love sleeping in a hammock, and recently got a camping hammock. Next on my list is one of those "tensahedron" rigs (some examples: http://www.tensaoutdoor.com/) that is designed for backpacking, and should work well in the plane... No way I'd ever try to hang one from a tie-down ring!
JP256 offline
Aircraft: Rans S-6ES
5 postsPage 1 of 1
