Does anyone know what baffle material is used in the valve assembly? I'm thinking it's the T-8071 Black Silicone engine baffle. Yes, no, maybe??
Thanks,
TJ Carr wrote:Does anyone know what baffle material is used in the valve assembly? I'm thinking it's the T-8071 Black Silicone engine baffle. Yes, no, maybe??
Thanks,
Thanks,
1SeventyZ wrote:My flapper is baffled with a weird felt-like material, if I remember correctly. Probably a good thing to get correct though as you don't want the brittling effect and then have chunks peeling off.
Glidergeek wrote:1SeventyZ wrote:My flapper is baffled with a weird felt-like material, if I remember correctly. Probably a good thing to get correct though as you don't want the brittling effect and then have chunks peeling off.
I thought you don't have an airplane anymore? You sold one and somebody crashed the other one you rented?
