Cessna 182B BREATHER HOSE
This subforum is meant to organize Cessna 182-related topics.
I NEED A NEW BREATHER HOSE FOR MY CONTINENTAL 0470. WHAT IS THE PART NUMBER AND WHERE IS THE BEST PLACE TO PURCHASE. IT GOES FROM THE OIL FILL TO THE BACK OF THE ENGINE. THANKS DICK
flyer offline
260
- Aircraft: Cessna 182B
The part number is 0500106-102. I'm pretty sure its just 5/8" or 3/4" ID aluminum pipe, your A/P should be easily able to make one for you, its not hard.
5218
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
Where did you get that part number? My breather from the oil fill to the back of the engine is a rubber type flexible hose. It attaches at the rear to an aluminum tube. Thanks for answering. Dick
flyer offline
260
2990
- Aircraft: None
flyer wrote:Where did you get that part number? My breather from the oil fill to the back of the engine is a rubber type flexible hose. It attaches at the rear to an aluminum tube. Thanks for answering. Dick
From the IPC. If its rubber someone has substituted it.
5218
