I know there's gotta be dozens of old pros here with more hours in 207s than this old plane even has on its airframe, so here's the story. I took off in -25F tonight (done it lots at -40) and everything was hunky-dory, quick 25 minute flight, I landed, shut down, opened the door and found the flaps still hanging down. Looked at the circuit breakers, all in, flap selector was up, so I turned the master on again. I heard the flap motor turning, but there was no flap movement. Flipped the flap selector up and down with no results, but the flap motor stopped when I selected 20 degrees. I got out and could move the flaps up and down by hand. Pulled the two inspection plates at the flap motor and the pulley, nothing obviously wrong, my guess is a shear pin or stripped gear? I decided it was probably going to fly home just fine with the flaps hanging in trail, so I unloaded all the crap I hauled and struck off home. I took off with the flap selector at 20 to keep the motor from running, and on the takeoff roll the flaps lifted to about 10 degrees as I expected they might. Once on course and level, they seemed to lower to 20 (it was dark, I could feel it). I raised the flap selector to 0 and lo and behold, the flaps came up. Then the circuit breaker popped, and I figured that was the best thing to happen all night. I made it home and left the flaps up on landing. They are still up and won't budge by hand, as normal. Now what? I have to bring this up with the mechanics in the morning, but I know for a fact they have as much experience with 207s as I do...the company has had this bird for less than a year after having a fleet of Cherokee 6's since the dawn of time.
