swixtt wrote:..... http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/35E842DF8127B61586256E0D00503AAE?OpenDocument and how one does the inspection of it? .....
No need to be a jerk Eric. He just asked a question to those of us that have experience. Ya the AD spells it out, but sometimes theres other info from people that have been there done that. If you dont know, then dont answer. Especially with a smart ass comment like that...hotrod180 wrote:swixtt wrote:..... http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/35E842DF8127B61586256E0D00503AAE?OpenDocument and how one does the inspection of it? .....
Did you actually read the AD? It pretty much spells out the inspection procedure.
Do you do it every year? Or at a certain hr count?hardtailjohn wrote:I've probably replaced at least a dozen rear bulkheads in the past 30 some years. I got to where I just pull the bolts and do the dye-pen anyway and have found more problems that way. I'd rather find them then, than later.
A1Skinner wrote:No need to be a jerk Eric. He just asked a question to those of us that have experience. Ya the AD spells it out, but sometimes theres other info from people that have been there done that. If you dont know, then dont answer. Especially with a smart ass comment like that...hotrod180 wrote:Did you actually read the AD? It pretty much spells out the inspection procedure.
A1Skinner wrote:Do you do it every year? Or at a certain hr count?hardtailjohn wrote:I've probably replaced at least a dozen rear bulkheads in the past 30 some years. I got to where I just pull the bolts and do the dye-pen anyway and have found more problems that way. I'd rather find them then, than later.
Thanks
David
hardtailjohn wrote:[
"To detect cracks and bolt looseness which could lead to inflight separation of the fin and rudder, within the next 50 hours' time in service after the effective date of this AD on all airplanes with 1000 or more hours' time in service, and thereafter at intervals not to exceed 1000 hours', except that 206 series airplanes with the floatplane vertical stabilizer are to be inspected initially at 500 hours and at 500 hour intervals thereafter, accomplish the following: "
It's a known "bad" area so it gets a bit of extra scrutiny at each inspection interval. We had 182's on fire patrol (in some pretty good turbulence) that were getting a 100 hour inspection every 10th day and even a bit more often sometimes (wasn't uncommon to fly sunup to sundown, 7 days a week)...I really got sick of looking at it every week or 2, but would rather find it then than later! We never had to ream any holes, but replaced some bulkheads. I got in the habit of putting a wrench on the bolts and giving them a twist to make sure they were still tight as well as all the other required inspection.
Zzz wrote:
Glad you're still bumming around these parts, John. You've been here longer than nearly anyone, and always a helpful post. Thanks.
