Backcountry Pilot • Cessna Lap Belts
Cessna Lap Belts
21 postsPage 1 of 21, 2
Cessna Lap Belts
Does anyone have a recommendation for a fixed seat belt assembly fabricator? Specifically, I need to replace the deteriorating removable lap belts for the rear jump seats in my C180.
Scolopax offline
Re: Cessna Lap Belts
These guys dun me good.
Belt Makers Inc
1815 West 205th St # 304
Torrance, CA 90501 - View Map
Phone: (310) 618-8868
Web: Beltmakers.net
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Prosaria offline
Maybe a little late to the party, but I've overhauled lap belts before. I build skydiving harnesses for a living, so I'm pretty familiar with webbing and thread...
1:1 Scale offline
Aircraft: Maule M4-220C
Kelly
Maule M4-220C
If you haven't already, check out eBay... search "aircraft seat belts".
You might find a set that matches yours.
bart offline
Aircraft: Cessna 180
TangoFox offline
Keep the Greasy side down!
TangoFox wrote:These should work for you
http://www.aircraftspruce.com/catalog/appages/seatbelt1b.php
Nice find, that beats the heck out of the BAS price...
Prosaria offline
This is exactly what I was hoping to discover. Thanks for the suggestions and offers everyone.
Scolopax offline
glacier offline
glacier wrote:If you get them from Spruce, could you report back on quality and fit? I have the Cessna jump seats in my 180, and need to replace my rear seat belts too. Hooker has a nice quality option as well, but last time I checked (a while back now) they cost a fair amount more than the Spruce ones.
Thanks in advance.
I'm ordering them tomorrow. I will let you know my impression when they are in my possession and installed.
Scolopax offline
These are what I ordered for my 170 with FA Dodge jumpseats. They worked well.
1:1 Scale wrote:Maybe a little late to the party, but I've overhauled lap belts before. I build skydiving harnesses for a living, so I'm pretty familiar with webbing and thread...
I need to make a mental note of this. The guy that used to make belts for Bearhawks, and other experimentals, died suddenly. I've been searching for another option but haven't found a satisfactory alternative. I may have to get in touch with you 1:1.
What's special about the Bearhawk seatbelts? I've replaced webbing for belts in the past, but when it came time to put harnesses in my Stinson, I just bought the Wag Aero option. Not sure what my plan is for the Maule yet.
1:1 Scale offline
Kelly
Maule M4-220C
There is nothing special about the BH seatbelts. Just webbing of the proper length put on an inertia reel. Everyplace I checked wanted at least double what the guy that used to make them charged. I think I found a satisfactory solution though.
Cub Crafters sells inertial reel lap belt / shoulder harness sets.
Two different length belts, to accomodate different attach points.
$359 per side.
http://store.cubcrafters.com/38-Shoulde ... _1281.html
I purchased, received and installed the units from Spruce. They are great. Smoothly operating hardware, decent quality and no surprises.
Scolopax offline
glacier offline
glacier wrote:A couple follow on questions: Is the length a good fit for a reasonable range of passenger sizes? And, are your anchors/attach points as per the factory jump seats, i.e., on the floor in the middle and tabs at the base of the bulkheads on the sides? Thanks!
The anchors in the plane are stock for the factory jump seats in a 1967 H-model 180 as you describe them. The length is within an inch of the factory belts. I did once put a pretty plump person back there and the belt fit, but just barely. It was not a 1-person operation. Any bigger and it wouldn't have worked out very well. I am considering swaging up a couple of 6 inch cable segments to avoid any embarrassment with passengers in the future.
Scolopax offline
glacier offline
One thing to keep in mind on a certified aircraft....approval is a big deal. TSO compliance isn't something to take lightly.
hardtailjohn offline
