Backcountry Pilot • Cessna Owner Advisory SEL-55-01
16 postsPage 1 of 1
Anybody had any hands on experience with this "Mandatory" service letter and or inspection?
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Re: Cessna Owner Advisory SEL-55-01
Although it was dated back in december, I just gkt it in the mail about a week ago.
If you go to the txtavsupport link toward the bottom of the letter, and register there, you can download the wblle SL includjng inspection instructions.
It invvez removjng the horiz stab.
hotrod180 wrote:Although it was dated back in december, I just gkt it in the mail about a week ago.
You get hacked Eric? Your spelling is usually better then this...
He's getting used to his new phone.
A long time ago I got an award on this site for the worst spelling. I shall step aside.
You don't have to remove the whole stabilizer, just the back where it hinges needs to be lifted up a little leaving jackscrews intact. I did something similar a long time ago when I replaced the bushings that the aluminum castings hinge on. Really not that hard to do.
Zzz wrote:
A1Skinner wrote:...You get hacked Eric? Your spelling is usually better then this...
What he said.
Anything needs serious typing, i have to break out the laptop.
Here is the service letter
https://support.cessna.com/custsupt/contacts/pubs/ourpdf.pdf?as_id=49452
All known issues with these airplanes nothing new. Not sure why Cessna found the need to make a SL over it after all these years.
PAMR MX offline
Glidergeek wrote:Anybody had any hands on experience with this "Mandatory" service letter and or inspection?
Unless it becomes an AD, "mandatory" only means mandatory if youre a commercial operation. Doesnt apply to Part 91 ops.
Thats my new encryption protocol.
Sometimes it works so well I cant even read it myself!
I saw this when it came in the mail last month. I need to replace those bushings at annual (next month) so I plan to have my IA comply with the advisory while we're in there just in case it becomes an AD. Has anyone used the PPonk bushings for the stabilizer? Are they different?
Thanks,
Asa
I am also curious about the PPONK bushings. They are roughly $20 more per bearing than the originals from Mcfarlane. Non-seaplane use, are they worth the extra $140 (if you do all of the tail) extra?
silflexer offline
I looked at Pponk's site and all I see for the back end is bearings for the rudder and elevator---nothing about the rear horizonal stab. brackets or bushings.
Sorry, I was speaking about the elevator and rudder bushings, probably outside the scope of this thread.
silflexer offline
Since we drifted a little, I think I like the idea of the Ponk bearings that are composite. I also think the McFarlane carb heat box bearings that are some kind of elastomer instead of the needle bearings is a good idea. I need to fix my carb heat box bearings and pretty sure I'll find the needles wore into the shaft making things loose.
Although not compulsory, I would like to disassemble the empennage on my airplane. Primary reason is to remove, clean, inspect, and lubricate the trim jacks, sprockets, and chain. Fully executing this service bulletin is an easy task to take care of while we're at it.
Thanks for posting. I'd heard about it, but this is a good reminder.
Pinecone offline
16 postsPage 1 of 1
